Optical Micrometer System
The LS-7010 optical micrometer system performs high-speed measurements on moving targets in fast production and assembly lines.
July 7, 2005
Resolution is 0.01 m with repeatability of ± 0.06 m. Samples are targeted at a rate of 2,400 samples/sec. The device has no motors or rotating prism mechanisms; instead a high-intensity LED light produces the continuous 6-mm-wide beam with no gaps in target detection. The addition of a high-speed linear CCD increases measurement speed and accuracy. The unit's sensor head has no moving parts, eliminating heat and vibration that affect sampling speed and measurement.
Keyence Corp. of America
50 Tice Blvd.
Woodcliff Lake, NJ 07677
(888) 539-3623
www.keyence.com
