Operation: Shrink labeling
Aug. 1, 2006
How does a typical labeling system work? Labeling products is a mass-production proposition, but its complexity is only growing with increasingly diverse
Labeling products is a mass-production proposition, but its complexity is only growing with increasingly diverse products in convenience, travel, and wholesale-club formats. It begins with wrapping (printed with names, company logos, and other information) that's pulled or stretched over product — whether containers of several items, or individual units such as juice, soap, or bleach bottles. Then, with shrink-wrap labeling, heat makes labels tighten onto the products.
PVC is the most common type of shrink film. Polyolefin film is more elastic; it's commonly used with foods because it does not release harmful chemicals when heated and stretched. It's also used for products having sharp corners, because it is less brittle and resists breaking.
For high production capacities, automatic equipment most commonly conveys product into machines, with adjustable-speed motors and drives controlling conveyor speed. For example, for thicker, slower-shrinking film gauge, feed rate might be slowed.
What is the primary type of motion in labeling?
After a product unit is inside the machine, it is pushed or placed into a labeling position. This labeling position is the station at which labels are affixed to the product. Here, some legacy sleeve wrapper designs use continuous-run rotary motors and clutches to push product from the conveyor belt into the labeling position; their speed and feed rates are limiting factors.
Actuator arms then pull film labels onto the product. In newer equipment these arms are positioned with servos. Pneumatically operated grippers at the arm ends grab the material and stretch it open slightly, and then the arms pull the label onto the product and align it. Once in position, the grippers release the label. Then the product is placed back onto the conveyor, to ride through a label-shrinking heat tunnel. The heat must be sufficient, but not so high as to damage product.
What are the main challenges to implementing motion in labeling processes?
Labeling must be fast, but as accurate as possible; there are always new applications in which product must move faster than existing machine speeds. It's during these times that application engineers often raise issues that designers haven't considered. For example, target load rates are often based on existing technology, designed when the goal was not speed, but to get a machine operating.
The faster the move, the more force or torque required. Identifying load is as simple as placing it on a scale. The caveat here is that load includes more than just product weight; it includes actuator arms and grippers, mounting plates, bearing plates, and even friction. To measure the latter, connecting a simple scale to the load and pulling it across the surface in question gives a fairly accurate value.
Defining a machine's move is as easy as identifying task cycle time: This is the total time in which the designer wishes to accomplish a certain move. For example, say one axis pulls the product into position while another grabs the label and pulls it onto the product; then the grippers release and the product is pushed back onto the conveyor. If a designer allocates 1.6 sec to this operation, will the motor have sufficient time to complete its tasks?
Maybe not. Moving the product into the machine might take 0.2 sec; after moving the product into the labeling position, pulling the label onto the product might take another 0.2 sec or more. Then, the gripper needs time to release before product can be pushed onward. If the gripper requires, say, 0.4 sec to release, the motor is left with only about 0.4 sec to move product into position, and the same to push it back onto the conveyor. What appears to be an easy move is actually rather fast. If the distance is 10 in., an assumed speed of
10 × 2/1.6 sec = 12.5 in./sec is actually 10 × 2/0.4 sec = 50 in./sec
Where can motion technology make the biggest difference in labeling applications?
Servos and motion control improve labeling equipment by boosting speed and improving consistency for lower reject rates and improved part quality. Traditional inverter and vector technology reaches peak torques of 150% to 200%, but servos can attain 300% and even up to 400%. This allows for high acceleration torque, which mean faster positioning. By increasing machine speed and acceleration, servos increase the number of items wrapped and reduce average product cost.
In labeling, servomotors and controls improve the cycle time from 3 to 1.5 sec — an 87.5% improvement. Additionally, machines are better at accurately and correctly orientating and positioning labels, reducing the reject rate by 75% on average. Maintenance downtime on labeling equipment is normally one week per year; with servo motion it is reduced to one day per year. So, if a labeling machine boosts profits by $6,000 per day, the improvement from servo control in the cycle time alone increases that to $11,250.
Software has taken the place of oscilloscopes for easier tuning and easier servo motion implementation. Windows-based graphical tools display parameters so engineers can adjust systems and monitor key machine variables more easily. Also, newer fieldbuses allow parameters to be changed over a common bus. Ethernet Powerlink is one example; it is a software interface utilizing Ethernet hardware. With it, motion and drive parameter setups are controlled over the bus from a central location.
Hardware choices include rotary and linear servomotors. Rotary servomotors utilize either ballscrews or belts and pulleys to convert rotary to linear motion, whereas linear motors drive directly. Each approach has advantages: Rotary systems are comprised of standard parts, many of which are usually in stock; linear motors are built to order. Additionally, each technology has speed, accuracy, and repeatability performance-to-cost advantages. A rotary motor with ballscrew can provide speeds up to 50 in./sec, compared to linear motor speeds in excess of 200 in./sec. Keep in mind, however, that overspecifying is not recommended.
MOTOR OPTIONS
Inverter induction Vector induction Servo dc ferrite Brushless rare earth Speed Typical Typical High Highest Range 300 rpm to base 0 rpm to base 0 to 6,000 rpm 0 to 12,000 rpm Starting torque 150% 150% 200% 400% Acceleration Typical Typical Fast Fastest Servos have speed range capability beyond the speeds of other technologies, made possible with peak torques of 300 to 400%.
For more information, call (800)8284920 or e-mail the editor at [email protected].
History of packaging
Before 1800, packaging was restricted almost entirely to containment for shipping, with minimum levels of protection and preservation. Grocery bags debuted in the 17th century, but it was not until the 19th century that practical bag-making machinery was developed. The 19th century also saw the emergence of metal cans (1810), setup boxes (1844), folding cartons (1879), and the bottle machine (1899).
Early in the 20th century, marketing-oriented packaging began to evolve and branding, quality, handling, and point-of-sale display became important attributes. By the end of World War II, packaging had become a major medium of advertising and marketing.
The Fair Packaging and Labeling Act of 1966 gave the Food and Drug Administration authority to determine that packages are labeled accurately. The 1990 Nutrition Labeling Act required packages to contain more nutritional information, forcing companies to relabel about 75% of all goods carried by supermarkets. Today, many manufacturers are working towards packaging that causes less damage to the environment.
Shrink wrap machines
  • Straight bar sealers are commonly used by video and music stores to wrap DVDs, CDs, and videotapes to cut the film around the product. L-bar sealers use an L-shaped bar to cut film around a product in one pass. These are also called impulse sealers because they use electricity rather than heat to cut film. These do not give off smoke like straight bar sealers.
  • Sometimes, wire cuts through shrink-wrap film. The drawback is that it gets dirty and wears over time, and needs occasional replacement.
  • Heat guns resemble hair dryers; heat tunnels utilize a conveyor to pull product through a heated area. Finished labels are more evenly shrunk.
  • Shrink wrap sealers are designed for sealing thermoplastic films and bags such as polyethylene and polypropylene.
  • To seal, vacuum sealers remove air from packages — which are then moved into a shrink tunnel where the excess wrap is shrunk further.
  • Sleeve wrappers are designed to wrap a wide variety of packages either individually, in short or long packs, or collated packs in trays. Band sealers allow continuous sealing of bags; they're suitable for packaging bags of spillable powders, liquids, and grains.
