The cylinders are available in all the popular NFPA mounting styles, with bore sizes from 1.5 to 6 in. and strokes to 48 in. Cylinder heads and caps are machined from aluminum bar stock and black anodized for corrosion resistance. Standard cylinder barrels are durable, hard-coated aluminum alloy tube. Optional composite barrels are stronger, impact resistant, and self lubricating with a low coefficient of friction for smooth operation and minimal heat build up.
Fabco-Air Inc., 3716 N.E. 49th Ave., Gainesville, FL 32609, (352) 373-3578, fabco-air.com
