New products: Thin, flexible heaters
Nov. 23, 2008
Polyimide (Kapton) Thermofoil heaters are for use in applications with space and weight limitations, or where the heater will be exposed to vacuum, oil, or chemicals, such as in medical devices, aerospace, aviation and opto-electronics.
A line of flexible heaters consists of etched-foil or wire-wound heater elements sandwiched between layers of flexible insulation that have uniform or profiled heat patterns. The heaters can integrate temperature sensors, flex circuits, instruments, and other electronics.
Silicone rubber heaters are vulcanized directly to metal parts without adhesives, making them suitable for use in food service, graphic imaging, and thermal-processing equipment.
Thermal-Clear heaters have a microthin wire-heating element between optical-grade polyester sheets to provide heat without blocking light. Applications include LCDs, cockpit displays, outdoor card readers, portable military radios and computers, and optical deicing and defogging.
The temperature and wattage capabilities of Mica heaters make them suitable for applications requiring fast warm up.
All-polyimide heaters are for applications requiring higher temperatures and watt densities, such as semiconductor- wafer processing, satellites, spacecraft, and packaging, fusing and splicing equipment.
Minco, 7300 Commerce Lane, Minneapolis, MN 55432, (763) 571-3121, minco.com
RS Expert Advice Podcast, Episode 17: Energy Storage Systems
In this episode of the RS Expert Advice Podcast, Joel Boone and Olivia Koicuba of Phoenix Contact introduce energy storage systems, applications, and components, including various...
