New Products: Sensor for C-Slot Pneumatic Cylinders
Aug. 21, 2008
The BMF 273 compact sensor, for use with C-slot-equipped pneumatic cylinders, is designed to indicate piston stroke end position.
The 25.7-mmlong sensor offers reliable sensing characteristics and a wide range of sensing performance. The BMF 273 is secured by a nonstripping screw, while the cable is also equipped to be secured within the C-slot by a custom-designed mini pop-in fastener. The highly accurate, low hysteresis sensor comes with an LED indicator light and uses advanced magnetoresistive technology.
Balluff Inc.
8125 Holton Dr.
Florence, KY 41042
(859) 727-2200
balluff.com
