New Products: Power Supplies Target Motors, Pumps
The Series is said to deliver up to 300% peak output power.
The units come in three nominal output voltages 24, 36 and 48 V and each can be adjusted up to +10%/20% of nominal voltage to accommodate nonstandard system voltages. The supplies accept 85 to 265-Vac input voltages and comply with SEMI F47 (with 200-Vac line or higher) and EN61000-3-2 harmonic and powerfactor correction standards. Standard are remote on/off and dc good signals, and overvoltage/overcurrent protections, and the 600-W model has a current-share signal for paralleling two units.
The power supplies’ internal fan permits operation at 10 to 70°C ambient. .
Lambda Americas
3055 Del Sol Blvd.
San Diego, CA 92154
(800) 526-2324
lambdapower.com
