The new IMH 832 Series Side Exit Chek Valve is said to provide the lowest pressure loss of any valve this size. At only 8 mm in diameter, the valve features a side-exit design which permits flow in excess of 6 gpm of water at 100 psid.
The valves feature low leakage, easy installation, and robust stainless steel construction, and are typically used in industrial hydraulic applications such as off-road equipment. The valves are 100% performance tested to ensure consistent, long-term performance.
The Lee Co.
Box 424
Westbrook, CT 06498
(860) 399-6281
leeimh.com
