New products: Field serviceable check valves
Nov. 23, 2008
Power Generation Chek Valves can be disassembled and serviced in the field using rebuild kits. The valves are suitable for use in purge air, water injection, and liquid-fuel applications.
Power Generation Chek Valves can be disassembled and serviced in the field using rebuild kits. Designed to customer requirements, the valves are available with or without a removable, washable Hi- Bar safety screen. The unit’s operate to 450°F and feature low leakage and high flow. The valves are suitable for use in purge air, water injection, and liquid-fuel applications.
The Lee Co., 2 Pettipaug Rd., Box 424, Westbrook, CT 06498, (860) 399-6281, theleeco.com
