Self-lubricating slewing rings
PRT slewing ring bearings use two self-lubricating, low friction polymer sliding elements in place of ball bearings.
Features & benefits
Polymer sliding elements of solid lubricant requiring no additional lubrication
Low coefficient of friction, chemical resistant, low moisture absorption, and good vibration dampening properties
Consist of aluminum housings with stainless steel screws
Available with ODs of 30, 60, 100, and 200 mm
igus Inc.
(800) 521-2747
www.igus.com
Circle 160
Programmable cameras
BOBCAT line of machine-vision cameras in 45 × 45 × 39-mm envelope offer advantage where space is limited.
Features & benefits
Easily replaces existing analog units, field-upgradeable firmware
Choice of five resolutions and sensors: Kodak VGA @ 120 or 210 fps; Sony 1.4 M @ 24 fps, 2.0 M @ 16 fps, and 5.0 M @ 15 fps
Horizontal and vertical binning at 2x, 3x and 4x from the factory, multiple programmable areas of interest, digital and analog gain
Auto gain, exposure control
Imperx Inc.
(866) 849-1662
www.imperx.com
Circle 161
Parallel grippers
EGN series of servo electric two-finger parallel gripers now include sizes 80, 100, and 160.
Features & benefits
Stroke per finger of 8 and 16 mm
Upward and downward expansion allows the exact size gripper for each task with the right specifications
High payloads and power reserves handle heavy components with gripping forces to 1,000 N
Prepositioning enables short closing times and high cycle rates
Schunk Inc.
(800) 772-4865
www.schunk.com
Circle 162
Ethernet connectors
RJ-45 modular plug and jack connectors offer IP67 sealing and quick-connect bayonet coupling suited for EtherNet/IP, DeviceNet, and ControlNet applications.
Features & benefits
Coupling mechanism provides positive locking for reliable connections in harsh environments
Housings are polarized to prevent mismatching
Plug kits available for stranded and solid conductors; bulkhead-mount receptacle permits pass-through applications
Tyco Electronics Ltd.
(800) 522-6752
www.tycoelectronics.com
Circle 164
Roller chain
PerforMax bushings offer roller chain improvements with upgraded performance and reliability.
Features & benefits
Lube grooves, heat treatment, and precise dimensions produce a solid bushing
Designed grooves extend life by combating wear
Available in sizes 80 to 140
U.S. Tsubaki Inc.
(800) 323-7790
www.ustsubaki.com
Circle 163
Sensors
Uprox + Factor 1 sensors now include IP69k washdown versions with temperature ratings from -40° to 100° C.
Features & benefits
316 stainless steel construction, liquid crystal polymer front cap resist moisture
Polypropylene cable jacket stands up to harsh chemicals, extreme temperatures
Longer sensing ranges detect all metals including stainless steel
TURCK Inc.
(800) 544-7769
www.turck.com
Circle 165
Accelerometers
Signal-conditioned accelerometers provide stable vibration measurement outputs over wide temperature range.
Features & benefits
Dc response accelerometers offered from ±2 to ±500 g
Integral temperature compensation provides output from -40° to 115° C
Gas-damped MEMS sensing elements for stable frequency response
Hermetically sealed assemblies protect against over-range shocks up to 10,000 g
Programmed for exceptional thermal stability and recalibrated for different signal outputs and scale factors
Measurement Specialties Inc.
(949) 716-7516
ww.meas-spec.com/vibration
Circle 166
Protective boots
Protective boots stop rod scoring, prevent nicks, and extend seal life by protecting cylinder rods from chips, abrasive particles, and impinging objects.
Features & benefits
Neoprene nylon coated fabric boots handle temperatures from -40° to 220° F
Materials for expanded temperature ranges and special requirements available
Request catalog PR-100
A & A Mfg. Co. Inc.
(800) 298-2066
www.gortite.com
Circle 168
PC belt
Pyrathane twisted connectable PC belts are now available to replace endless belts in diameters from 3/32 to 9/16 in.
Features & benefits
No disassembly when replacing belts on line shaft conveyors and other applications
Originally designed as quick fix, but now a permanent replacement in many applications
Available in standard black 83A durometer
Other colors and durometers available
Pyramid Inc.
(641) 792-2405
www.pyramidbelts.com
Circle 169
Step motor driver
DRV-1 is a 1 amp, microstepping driver suitable for a range of resolutions.
Features & benefits
Six resolution settings from full to 1/32 step
Includes small (2.7 × 3.1 × 1.0 in.) heat-sink mounted footprint, 31.25 kHz step clock, over current protection, and mating connectors
Factory programmable for plug and play operation of up to four user-determined constant velocity motion profiles
Advanced Micro Systems Inc.
(800) 234-2001
www.stepcontrol.com
Circle 167
Transport system
MagneMover shuttle combines the QuickStick LSM product line with standard aluminum track and vehicle components for flexible turnkey transport.
Features & benefits
High-speed transfer shuttle allows a range of system layouts; tightly spaced return paths save floor space
Moves carriers at faster speeds and accurately positions loads to facilitate on-carrier work processes and higher throughput
Carriers can be stopped anywhere along the transport track; location can be changed in a few computer keystrokes with no mechanical parts or adjustments
MagneMotion Inc.
(978) 461-5090
www.magnemotion.com
Circle 170
Brushless servomotor
BSM132 high-power brushless servomotor ranges from 20 to 34 hp with optional blower cooling.
Features & benefits
Continuous stall torque from 620 to 1,060 lb-in. and speed capability to 5,000 rpm
Double insulated, multicoated magnet wire for reliability
Premium grease provides four times longer life
Quality servo-rated ball bearings offer durability and smoothness
Sealed to IP65
Baldor Electric Co.
(479) 646-4711
www.baldor.com
Circle 171
