Microstepping driver
RoHS compliant version of R208 microstepping driver features a compact design with low power dissipation and automatic current reduction.
Features & benefits
  • Provides up to 2.0 A phase current to any bipolar step motor
  • Micro stepping resolution can be set from full, ½, ¼, and ⅛ step
  • Uses 12 to 24 Vdc power supply to produce constant sinusoidal current waveforms
  • Recognizes step pulses from controller from rising or falling edge
  • Allows changes to amount of holding current applied to motor
Lin Engineering
(408) 919-0200
Circle 161
Parallel grippers
JGP pneumatic parallel grippers are extremely compact and universal for use in clean to slightly dirty environments.
Features & benefits
  • Available in sizes 64 to 160
  • Fits limited space and when interfering contours must be avoided
  • Oval pistons, wedge-hook kinematics, and T-slot guidance help achieve gripping forces of 56.2 to 537.3 lbf at a weight of 0.6 to 7.3 lb, depending on size
  • Stroke ranges from 0.24 to 0.63 in./finger
  • Recommended workpiece weights are 2.8 to 18.1 lb in standard cases
Schunk Inc.
(800) 772-4865
Circle 162
Timing belts
Three new high-performance industrial timing belts — Conti SynchroForce CXP, SynchroForce CXA, and the SynchroForce Extreme — are available in four different compounds for three section types.
Features & benefits
  • CXP delivers improved power transmission and wear resistance with its fiberglass tension member and polychloroprene elastomer
  • CXA uses N-Duro compound to increase residual tear strength and lifespan, for slow-running drives where high torques are transmitted
  • Extreme version suits drives with pulsating forces and torques and is based on a refined HNBR polymer for reliable transmission of shock movements
  • Available in pitches of 3, 5, 8, and 14 m and sections STD, HTD, and CTD
ContiTech Power Transmission Group
(800) 654-0974
Circle 163
Single-axis control
Freedom Series motion control development tool eliminates the confusion associated with motion systems integration.
Features & benefits
  • This all-inclusive package features utility and design flexibility found in higher-level control systems
  • Choice of four brushless motor options from 16 to 40 mm in diameter and up to 1/6 hp
  • Equipped with GUI software and easy-to-follow instructional wizards along with practical exercises
  • All cables and connectors are included in plug ‘n play package
Maxon Precision Motors Inc.
(508) 677-0520
Circle 164
Ac servomotor
EXC-series ac servomotor is a cost-improved version of the N-series family of ac servomotors from Rockwell Automation for use in light industrial, commercial, and medical applications.
Features & benefits
  • High acceleration and speed capability
  • Environmental sealing
  • Compatible with most drives, including OEM designed electronics
ElectroCraft Inc.
(603) 742-3330
Circle 165
