Protected to IP55, the load cells are constructed of lightweight aluminum for ranges up to 1,000 lb and stainless steel for ranges over 1,000 lb. An IR 0.25% interchangeability makes the cells suitable for multiple load-cell applications. Supplied with a 20-ft, four-conductor jacketed cable, the S-Beam load cells are used in tension and tension calibration is provided.
Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (800) 826-6342,
load cells
