New Product: Differential Flowmeter
The meter’s minimally invasive segmented wedge design is said to be low cost and require little maintenance. Flow rates of 5 to 15 gpm are relayed wirelessly up to 200 ft. The sensors have an accuracy of ±2% and a precision of ±0.5% of full scale up to 125 psi and 170°F. Tap water at 70°F is the recommended calibration media.
The end ports and wedge are constructed from durable PVC. Polyetherimide forms the unit’s housing. For 0.75-in. tubing, the meter is 7.5 5.25 2.22 in. Smaller diameter piping allows shorter dimensions. Meters can be flange mounted in any orientation with or without straight inlet or outlet plumbing.
AW-Lake Co.
8809 Industrial Dr.
Franksville, WI 53126
(800) 850-6110
aw-lake.com
