Mounting brackets
March 16, 2011
The MH01-M18 half-clampstyle mounting brackets, for use with the company’s ML17 and M18 photoelectric sensors, let sensors be quickly turned on several axes for easy adaptation to changing multiaxes alignments.
The MH01-M18 half-clampstyle mounting brackets, for use with the company’s ML17 and M18 photoelectric sensors, let sensors be quickly turned on several axes for easy adaptation to changing multiaxes alignments. They fasten on a 12-mm (0.5 in.) diameter rod or bolt common to packaging and material-handling equipment. Once fastened, the bracket can be rotated 360° around the rod or bolt to best align the sensor.
Pepperl+Fuchs
1600 Enterprise Pkwy.
Twinsburg, OH 44087
(330) 486-0001
www.pepperl-fuchs.us
© 2011 Penton Media, Inc.
