Type 3RD is a double-reduction gearhead for applications requiring very slow rotation and very high torque. The unit produces output of 0.5 to 8.5 rpm with gear ratios of 200:1 to 3,600:1 and 148 lb-in. of torque.
With an offset driveshaft, Type HG can be face mounted from either side. The unit produces output from 16 to 63 rpm with gear ratios of 27:1 to 108:1, and 1,000 lb-in. continuous torque.
Designed for higher-than-usual performance, Type CG produces output from 24 to 85 rpm with gear ratios from 20:1 to 72:1 and 1,000 lb-in. of torque.
Bodine Electric Co.
2500 W. Bradley Place
Chicago, IL 60618
(773) 478-3515
