Motorized Flow Control
Aug. 23, 2007
The Generation II motorized flow and pressure controls feature a planetary reducer and heavy-duty motor.
The Generation II motorized flow and pressure controls feature a planetary reducer and heavy-duty motor. The controls are available in nine operating speeds ranging from 1 to 48 sec to travel from full-open to full-shut and vice versa. The units can control anything from a simple toggle or rocker switch to a closed-loop system. The controller can be operated by potentiometer, 4- to - 20 - mA , 0-to-10 V, or PWM signal. Available flow ranges include 0 to-3 gpm up to 0-to-120 gpm at 100-psi pressure differential. Motorized-relief and reducing-relieving valves come in pressure ranges to 5,000 psi and flows to 15 gpm.
Source Fluid Power, 331 Lake Hazeltine Dr., Chaska, MN 55318, (952) 368-3866, sourcefp.com
RS Expert Advice Podcast, Episode 17: Energy Storage Systems
In this episode of the RS Expert Advice Podcast, Joel Boone and Olivia Koicuba of Phoenix Contact introduce energy storage systems, applications, and components, including various...
