New R88D-GN and GT Series servodrives and R88M-G Series servomotors feature real-time autotuning and adaptive-vibration suppression. Adaptive-vibration suppression reduces the amount of vibration as work travels between positions, shortening positioning time and improving accuracy for higher productivity. The G-Series servodrives come with a high-speed network drive (-GN) or standard analog/pulse output (-GT) and work with a wide range of R88M-G servomotors. The R88D-GN Models exchange data via high-speed Mechatrolink-II motioncontrol bus. Single bus connections let parameters be set and monitored simultaneously for multiple drives. Multiple servodrives can be set with the same parameters using a copy function built into the handheld keypad and the configuration software. G-Series servodrives are available in 50-W to 7.5-kW Models, in 120 and 240-Vac single-phase and 240-Vac three-phase versions. They work with servomotors available in 3,000, 2,000, 1,500, 1,000 rpm, with absolute and incremental encoders. Motor options include straight shaft, key tap shaft, brake and oil seal.
Omron Electronics LLC
1 Commerce Dr.
Schaumburg, IL 60173
(866) 886-6766
