Polyurethane tubing resists kinking and abrasion and sports superior memory, elasticity, and resistance to water, ozone, oil, and grease. ID ranges from 1/16 to 1/4 in. Working pressure at 75°F ranges from 93 to 176 psi and 47 to 88 psi at 150°F.
Coiled polyurethane tubing has a maximum extended length of 10 ft with 8 ft of working length. It's available with one 16-in. straight tail and one 8-in. tail. ID ranges from 1/16 to 1/4 in., and custom configurations are available.
High-pressure tubing can be used with compression fittings. ID ranges from 1/32 to 0.170 in. Working pressure at 75°F ranges from 172 to 2,400 psi and 68 to 2,400 psi at 150°F.
Beswick Engineering Co. Inc.,
284 Ocean Rd., Greenland, NH 03840,
(603) 433-1188, beswick.com
