A line of EtherNet/IP machine-mount I/O blocks lets designers seamlessly integrate a broad range of compatible connectivity products from many manufacturers. The line includes 12 versions of machine-mount I/O blocks and an IP67 unmanaged switch. Fast IP addressing comes from using BOOTP/DHCP, through an IP67 IP Address Plug (IPAP) via a pushbutton display (100 Series only), or Web pages. The addressable display shows all the octets of the IP address, subnet mask, and gateway address while pushbuttons allow for octet adjustment of the IP address, subnet mask, and gateway address. Detachable for rapid module replacement, the IP Address Plug (IPAP) stores the module’s addressing information in a quick-disconnect unit.Balluff Inc., 8125 Holton Dr., Florence, KY 41042, (800) 543-8390, www.balluff.com
