Low-viscosity epoxy - MasterBond
March 15, 2010
EP21FL is a toughened, low-to-moderate viscosity, two-part epoxy.
EP21FL two-part epoxy resin works between -60 and 250ºF and resists thermal cycling and shock. Typical viscosity at 25°C is 4,000 cps for Part A and 10,000 cps for Part B. Bond strength is over 1,500 psi and tensile strength exceeds 1,100 psi. The hardened compound has volume resistivity greater than 1012 ohm-cm.
The epoxy comes in in half-pint, pint, quart, 1-gal, and 5-gal kits.
Master Bond Inc.
154 Hobart Street
Hackensack, NJ 07601
(201) 343-8983
www.masterbond.com
June 27, 2025
June 25, 2025
June 25, 2025
