Low-Backlash Gearboxes
Nov. 18, 2010
Small, right-angle gearboxes, developed for camera-positioning applications, feature 4 arc-min backlash
Small, right-angle gearboxes, developed for camera-positioning applications, feature 4 arc-min backlash. The worm/ wheel gearbox uses a singlepiece carbon- steel worm and input shaft, machined aluminum block housing, dual ball bearings for shaft supports, and output bore with optional stainless output shaft.
Additional features include –40 to 100°C operation, 5:1 to 120:1 ratios, and torques to 36 lb-in. at 2,000-rpm input with the P20 or P30. Larger gearboxes with torques to 540 lb-in. at 2,000 rpm with 4 arc-min of backlash are available.
Rino Mechanical
216 N. Main St.
Freeport, NY 11520
(888) 260-7466
www.rinomechanical.com/gearbox_low_backlash.htm
© 2010 Penton Media, Inc.
