Linear Potentiometer
The MLP linear potentiometer is designed for use in both hydraulic and motor-driven applications.
Feb. 22, 2007
The MLP linear potentiometer is designed for use in both hydraulic and motor-driven applications. The unit has a full-stroke range from 0.5 to 6 in., 0.5% FS accuracy, <0.01 mm repeatability, and >25 million cycle life. The potentiometer's twin-bearing actuating rod, backlash-free pivot heads, and wiper system prevent dirt from entering the housing. Operating temperature range is –22 to 300°F.
Celesco Transducer Products Inc.,
20630 Plummer St., Chatsworth, CA 91311,
(800) 423-5483,
celesco.com
