Linear Measurements In Harsh Environments
The PT9150 Cable-Extension Position Transducer measures up to 550 linear inches with an encoder pulse output.
Jan. 12, 2006
Measurements are made with a stainlesssteel rope wound on a spring-loaded spool, which turns the shaft of a rotary encoder. The rope can also be nylon coated or made of thermoplastic. The device is rated to IP67 and is designed for harsh environments. For sidewall mining, for example, the PT9150 can be equipped with a high-voltage line driver output and a resolution of 100 pulses/in. TTL and 5V line driver options are also available, as are resolutions from 10 to 250 pulses/in. The cable can exit from the front, rear, top, or bottom of the steel or aluminum enclosure.
Celesco Transducer Products Inc., 20630 Plummer St., Chatsworth, CA 91311, (800) 423-5483, celesco.com
