Linear Actuators
June 2, 2005
The HD-Series and A-Series actuators feature die-cast aluminum powerheads, zinc-plated inner and outer tubes, factory-set torque limiters, and can be specified with 12, 24, or 36 Vdc and 110 or 220 Vac.
Designed to handle moving loads up to 2,500 lb and static loads to 5,000 lb, the HD-Series Acme screw actuators are for use in agricultural, construction, and off-road vehicles, as well as adjustable seat mechanisms, aircontrol and venting equipment, satellite-dish positioners, lift tables, and personal handicap equipment. Stroke lengths range from 4 to 48 in. with three gear ratios: 17:1, 25:1, and 55:1.
For more demanding applications, the A-Series actuators have dynamic load capacities to 3,000 lb and static loads to 5,000 lb. The actuators are designed with either round 2.25-in. or square 2.5-in. tubing and a .75-6 Acme screw. Gear ratios are 34:1 or 110:1 and stroke lengths are 4 to 18 in.
Burr Engineering & Development Co.
Box 460
Battle Creek, MI 49016
(269) 966-3122
burractuators.com
March 13, 2024
March 13, 2024
March 13, 2024
Smooth Sorting with SEW-EURODRIVE!
Feb. 22, 2024
Sorting systems are essential when it comes to warehouse automation, material handling, and distribution. SEW-EURODRIVE’s automated sorting solutions increase capacity, reliability...
