Leveling Mounts
An expanded line of inch-size, threaded, stud-type Level It leveling mounts are made of carbon steel with a gold-iriditeplated or black-oxide finish.
The stud comes with a jam nut and its ball end is machined from solid bar. The mounts swivel 10 to 15° to all sides of the centerline to adjust to uneven surfaces and is used for leveling machine tools, electronic racks, benches, and more.
Modifications including lag bolt holes and other plating types are available on request for certain minimum quantities, as well as nonskid elastomer pads.
J.W. Winco, 2815 S. Calhoun Rd., New Berlin, WI 53151, (800) 877-8351, www.jwwinco.com
