Joystick With Thumbwheel
The XL-VNSO joystick is for high-duty-cycle applications and rough use.
Aug. 10, 2006
The one, two, and three-axis joystick features an electronic amplifier for precise control of electrohydraulic proportional valves used in off-road mobile equipment, as well as uses needing digital or analog command signals to control variable-speed drives, PLC, and microprocessors. The device is constructed with nickel-chromium gimbal yokes, hardened-steel bearings, polished-steel shaft guides, bronze gate handle stops, and dual-compression return springs in each axis.
J.R. Merritt Controls Inc.,
55 Sperry Ave., Stratford, CT 06615,
(800) 333-5762, jwmerritt.com
