IP65/67 Connector
The IP65/67 interconnect is UL listed for the following contacts with screw, solder, and crimp terminations: 3+PE, 16 A/400 V and 6+PE, 10 A/250 V. The cable housing is designed for easy assembly of 6 to12.5-mm cable diameters. The connector's mechanical coupling is ergonomically shaped and vibration resistant for rapid mating and un-mating in extreme environmental conditions. Amphenol-Tuchel Electronics, 6900 North Haggerty Rd., Suite 200, Canton, MI 48187, (734) 451-6400, amphenol-tuchel.com
