Inside out
April 1, 2005
Usually a motor's rotor is on the inside and usually that's okay except when power density is an issue. This being the case in a new line of motors, the
Usually a motor's rotor is on the inside and usually that's okay — except when power density is an issue. This being the case in a new line of motors, the magnetic rings are on the outside for high speeds and accelerations. With the rotor designed into the motor's outer piece, the effective gap diameter between the magnet and the coil is allowed to be much larger, generating higher torque in the same envelope.
VITAL STATS
On display: RI and RE-Series motors
Key features: Rotor and magnetic rings are on the outer shell rather than inside.
What it means to you: Peak torques to 10,000 Nm, detent forces as low as 0.1 to 0.3% of the peak value
What else: 20 design variants available; encapsulated cooling system integrated into the stator or core; suitable for machine tool and grinding machine applications.
Innovator: LAT of the Schaeffler group's INA
For more info: Call (803)5488500 or visit www.www.ina.com/inaupdate.
