Input Meter With Software
May 5, 2005
Crimson 2.0 is a suite of programming tools for creating control and monitoring routines on G3 Series operator-interface panels and Modular Controller Series.
Users are guided with a series of menus and pop-up windows when configuring settings for the PAX Dual Process Input Meter (PAXDP) and able to save settings for retrieval. Archiving and retrieving a PAXDP programming setup is simplified, the company claims, making "quick work" of programming multiple meters to do the same function, or restoring saved programming to a replacement PAXDP meter. The Dual Process Input Meter is a two-in-one process-control solution that lets users monitor, scale, and display two independent input sources, perform a high-speed math function on the input values, and display the result. It can be set up to display input values from both signal sources, and to calculate and display a result based upon both input values. With optional plug-in cards, the meter can be equipped to generate desired outputs including alarm triggering, retransmission of analog output, or sending data via communication protocols. Crimson 2.0 is downloadable and freely available with free upgrades.
Red Lion Controls Inc.
20 Willow Springs Circle
York, PA 17402
(717) 767-6511
www.redlion.net/
March 13, 2024
March 13, 2024
March 13, 2024
Smooth Sorting with SEW-EURODRIVE!
Feb. 22, 2024
Sorting systems are essential when it comes to warehouse automation, material handling, and distribution. SEW-EURODRIVE’s automated sorting solutions increase capacity, reliability...
