Industrial Monitors
The PHM Flat-Panel Industrial 15 and 17-in. TFT monitors carry a NEMA-4/4x-rated display.
Dec. 14, 2006
A 15-in. version also comes with a stainless-steel bezel that is suitable for sanitary and clean-room applications. The CTC-designed monitors come with an analog resistive touchscreen and standard serial output, along with a standard connection to any PC through analog RGB 15-pin DSUB input. The unit's auto-power-sensing function activates the monitor when a video signal is detected and shuts down when the signal is not present. The monitors are 24-Vdc powered with an option for an ac adapter. The lightweight monitors have a 2.4-in. slim-profile backshell and easily mount in cabinet and swing-arm configurations.
Parker Electromechanical Automation Div., 50 W. TechneCenter Dr., Milford, OH 45150, (513) 831-2340, ctcusa.com
