Induction heating and laser inspection
Feb. 20, 2002
An integrated system combines induction-heated adhesive curing with robotic part handling and laser inspection to help process and inspect steel or aluminum doors, hoods, deck lids, and other automotive closures.
An integrated system combines induction-heated adhesive curing with robotic part handling and laser inspection to help process and inspect steel or aluminum doors, hoods, deck lids, and other automotive closures. The system replaces separate curing and inspection stations with a single robotic system. Parts are processed and inspected in body position using the same tooling. After parts are presented to the robot, the inductors are indexed into preliminary position and self-locate the part. The adhesive cures in 8 to 10 sec. After heating, the laser measures the completed assembly. Laser check is a simple go/no-go inspection, and tolerance is typically 0.7 mm.
Robotron Corp., 21300 Eight Mile Rd., Southfield, MI 48075, (248) 350-1444.
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
