Hydraulically balanced diaphragm pumps
H25 Metering Series Industrial Pumps are engineered to pump solutions up to 1,200 gpm, while providing ±1% steady-state accuracy with a 10:1 turndown ratio. The H25 operates smoothly and quietly and requires low horsepower. While the pump's rugged design lets them operate at 1,000 psi, metering is just as accurate at 50 psi. The units can run dry without damage, and have no troublesome cups, packings, and seals, resulting in fewer problems, less maintenance, and longer pump life.
Hydra-Cell Industrial Pumps, Wanner Engineering Inc.,
1204 Chestnut Ave., Minneapolis, MN 55403,
(612) 332-5681, hydra-cell.com
