Hydraulic and Pneumatic Valves: Solenoid and Air-Pilotoperated Valves
April 7, 2009
The new “22” Series solenoid and air-pilot-operated valves come in three and four-way configurations with /-NPT (F) ports
The new “22” Series solenoid and air-pilot-operated valves come in three and four-way configurations with / -NPT (F) ports. These valves provide a 40-scfm flow rate at 125 psi and feature single or double air-pilot and solenoid operators. The 1-W, 15-mm solenoid valves use less power and have a variety of connector and voltage options. The four-way valves have a threeposition version with either closed or exhaust centers. A PneuTef process permits use with lubricated and nonlubricated air. A special seal material also accommodates low-temperature applications. Two to 10-station manifolds are available for mounting convenience.
Pneumadyne Inc.
14425 23rd Ave. N
Plymouth, MN 55447
(763) 559-0177
pneumadyne.com
