High-Voltage On/Off Controllers
Adam 4069 and 5069 modules are designed to switch on and off high-voltage applications such as lights, fans, alarm systems, and various electronic devices in industrial automation.
March 23, 2006
They each have eight output channels rated at 240 Vac at 5 A or 30 Vdc at 5 A. The Adam-4069 supports the Modbus/RTU protocol and Adam ASCII commands. It also has four Form-A and four Form-C relays. The 5069 provides jumper settings for output values to clear or keep values when reset. Keeping the last output value eliminates the risk of uncontrolled output signals after accidental power shutdowns. It has eight LEDs showing its status and eight Form-A relays. When used with selected controllers, the 5069 provides Modbus/RTU or Modbus/TCP protocol for communication.
eAutomation, a div. of Advantech, 1320 Kemper Meadow Dr., Suite 500, Cincinnati, OH 45240, (800) 205-7950, Advantech.com
