Corr-Paint CP4070 is a blue-pigmented, silicone-based coating for protecting large aluminum and steel structures in industrial applications up to 1,100F. The water-dispersible coating adheres to sandblasted as well as marginally prepared metal surfaces. It is said to dry rapidly at room temperature and cure easily. The coating keeps its color at high temperatures and resists oxidation, ultraviolet light, humidity, and salt spray.
Corr-Paint is applied using conventional pneumatic spray equipment, brushes, or rollers. Applications include heat exchangers, crackers, reformers, and exhaust ducting. It comes in pint, quart, gallon, and 5-gallon pails.
Aremco Products Inc.,
707-B Executive Blvd.,
Valley Cottage, NY 10989,
(845) 268-0039,
