High-Pressure Valves
May 5, 2005
Family of high-pressure valves includes 70-100 air sequence valves to operate pumps or other air-operated functions with range from 25 to 100 psi and 1/2-in. ports.
CV Series in-line check valves available in sizes 1/4 to 1-in. NPT and pressures up to 15,000 psi. Normally closed 20-400 air-pilot unloading valve releases and unloads pressure with a rating up to 30,000 psi. PUV normally open air pilot pressure release valves release hydraulic pressure when air pressure is turned off, and is available in 55:1 and 120:1 ratio models. V103 air-pilot switch valves come in two or three-way configurations, normally open or closed. Sensing port handles up to 30,000-psi liquid or gas. Model 20-500 direct-acting relief valve comes in 1/4-in. NPT or high pressure 9/16-18 coned fittings for liquid or gas up to 60,000 psi.
SC Hydraulic Engineering
1130 Columbia St.
Brea, CA 92821
(714) 257-4800
www.schydraulic.com
RS Expert Advice Podcast, Episode 17: Energy Storage Systems
In this episode of the RS Expert Advice Podcast, Joel Boone and Olivia Koicuba of Phoenix Contact introduce energy storage systems, applications, and components, including various...
