High Efficiency, Sub-Miniature Step Down Regulators
June 7, 2006
The C&D Technologies series of Datel 78SR switching regulators are perfect for cost-sensitive applications where the maximum load current is half an amp or less.
The C&D Technologies series of Datel 78SR switching regulators are perfect for cost-sensitive applications where the maximum load current is ½ an amp or less. 7805SR (+5V/0.5A), 7812SR (+12V/0.4A) and 7803SR (+3.3V/0.5A) are high efficiency, easy-to-use, drop-in replacements for power-hungry LM78xx linear regulators. They're 100% pin- and size-compatible with industry-standard, 3-pin TO-220 plastic packages.
Two package styles are available: a standard vertical-mount SIP that occupies less than 0.1 square inch of pc-board real estate, and a horizontal-mount version that allows for an installed height of less than 0.350 inches.
78SR Series' 260KHz switching frequency produces efficiencies as high as 95% for 12V models, and 85% for 3.3V and 5V models. Full-load operation from 9V, 12V, 24V, 28V or 36V supplies-at ambient temperatures as high as +70°C-requires no heat sinks, no forced-air cooling, and no temperature derating, making the 78SR a cost-effective alternative in new and existing LM7805/LM7812 designs. And the high efficiency can dramatically increase battery life in portable instrumentation and standby-power applications and other applications that require full-load operation at elevated supply voltages and/or elevated temperatures.
78SR Series switching regulators offer additional improvements over their linear counterparts, including lower quiescent current (3mA vs. 5 mA), higher operating input voltage (+36V vs. +32V), and significantly tighter output accuracy (±1.5% vs. ±5%). Their excellent line and load regulation of ±0.3% and ±0.2%, respectively, allows operation from poorly regulated dc supplies. And, unlike their linear counterparts, these switchers don't need any external input or output capacitors to provide stable, low-noise outputs.
78SR Series regulators are priced at $9.95 in singles and drop to below $5 in OEM quantities. Small-quantity orders are available from stock. Samples are immediately available from stock.
Contact:
C&D Technologies, Inc.
Power Electronics Division
11 Cabot Boulevard
Mansfield, MA 02048-1151, USA
Phone: (508) 339-3000
Fax: (508) 339-6356
Web: www.cd4power.com
E-mail: [email protected]
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
