Seven new product families for heavy-duty industrial valves are available.
CB counterbalance valve, 10 design — Features a “zero-lead, soft-shift” capability and is available for cartridge, subplate, and SAE flange mounting. Available in 12, 16, 25, and 32 sizes and rated at 350 bar and 560 lpm.
DARV (direct-acting relief valve), 10 design — For cartridge, subplate, and in-line mounting. Available in 6 through 30 sizes and rated at 400 bar and 350 lpm.
DGM*-H8, D08 stack valve, 10 design — Available as a pilot operated with check rated at 315 bar and 450 lpm or as a throttle valve with check rated at 315 bar and 350 lpm.
DGM*-7, D07 stack valve, 30 design — Available as a pilot operated with check rated at 315 bar and 300 lpm or as a throttle valve with check rated at 315 bar and 250 lpm.
FCG-H02 & 03, flow-control valve, 10 design — Pressure compensated and rated at 315 bar and 160 lpm. Available for subplate mounting in DIN 24340, form G; ISO 6263; CETOP-RP 121H, and NFPS 3.5.1 MR1 configurations.
CG2V-10 and CG5V-10 pressure-relief valves with optional solenoid venting function, 10 design — Available for subplate mounting in ISO 6264-10 or NFPA/ANSI R10 configurations and rated at 350 bar and 650 lpm.
X(C)G2V-10 pressure-reducing valve, 10 design — Available for subplate mounting in ISO 6264-10 or NFPA/ANSI R10 configurations and rated at 350 bar and 400 lpm.
Eaton Corp., Hydraulics Group, 14615 Lone Oak Rd., Eden Prairie, MN 55344, (952) 294-7992, www.eaton.com/hydraulics
