The Gen2 electromagnetic packaged clutch/brake UniModule is designed for heavy-duty conveyor applications. A new, larger bearing provides a 47% increase in dynamic load. A redesigned armature and spline hub offers an 83% increase in spline length, resulting in a 44% decrease in spline-compressive stress. Two assembled, preburnished, heavy-duty UniModules are offered for 143/145TC NEMA frame, up to 2 hp.
Standard features include internal component mounting; an external housing-fin design increases heat dissipation and optimizes stop/start frequencies; an improved input-to-output axis alignment reduces vibration, noise, and wear; and integrated, custom mounting bolts let the conduit box be located on top of the unit for more consistent orientation.
Warner Electric, 449 Gardner St., South Beloit, IL 61080, (800) 234-3369, www.warnerelectric.com
