Header Cables
Oct. 26, 2006
HD-G4F6 cables connect Snap Pac programmable automation controllers and Snap Ethernet I/O systems to plugin, single-channel G4 digital I/O racks.
The cables measure 6 ft in length and include header connectors at each end for connecting two G4 digital I/O racks with a Snap 32-channel digital module. The cable is primarily designed for use in existing applications where G4 digital I/O points are connected to a PLC or PC via ribbon cable. Each 32-channel module-cable-G4 I/O rack combination provides 32 points of channel-tochannel isolation, 4,000-kV isolation from the field side to the control side, and an increase from 100-mA switching and sensing on Snap 32-channel I/O to 3-A switching and sensing in the G4 digital I/O line. In many cases, the latter eliminates the need to add interposing relays.
Opto 22, 43044 Business Park Dr., Temecula, CA 92590, (800) 321-6786, Opto22.com
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
