Handheld Calibrator
This four-in-one handheld device provides multilevel, cross-parameter measurements recorded 15 to 50% faster than before, The DPI 880 measures and sources milliamps, millivolts, volts, ohms, frequency, thermocouples, RTDs, pulses, and pressure.
It also captures switch values and provides 24-volt loop power. Dual readings of both input and output parameters and internal data logging simplify calibration and system diagnostics. Thermocouple transmitter calibration results are ready to print in 5 min. The calibrator has a built-in Hart loop resistor.
GE Industrial Sensing, 1100 Technology Dr., Billerica, MA 01821, (800) 833-9438, gesensing.com
