Gender Changer Plates
June 17, 2004
Gender changer plates are specialty flange plates used for greater flexibility in assembly of Inserta modular valves and connectors, four-bolt flange type.
GENDER CHANGER PLATES
Gender changer plates are made with a nominal-size center hole. This permits two O-ring clamplike flange faces to join together with O-rings sealing on the opposing gender changer plate surface. These plates range in size from 1/8 to 2 in. and are made of steel.
Inserta,
538 Township Line Rd., Blue Bell, PA 19422,
(215) 643-0192,
www.inserta.com
