The material's soft and compliant resin formulation does not crumble, flake, tear, or come apart, making it suitable for fragile components. The material has an asymmetrical laminate construction with embedded-fiberglass reinforcement on the top side for puncture, shear, and tear resistance, and a naturally tacky lower-modulus gap-filling rubber on the bottom. Both sides of the material have natural inherent tack, eliminating the need for additional adhesive layers. The material comes in 8 3 16-in. sheets or as die-cut parts in standard thicknesses of 20 to 125 mil.
The Bergquist Co., 18930 West 78th St., Chanhassen, MN 55317, (800) 347-4572, www.bergquistcompany.com
