Machinedesign 1221 1011 Cisco Download 0 0
Free guide explores plantwide Ethernet, motion control integration
Oct. 1, 2011
For applications requiring highly integrated motion control, such as packaging, pick-and-place, converting, assembly, and robotics, the network infrastructure
For applications requiring highly integrated motion control, such as packaging, pick-and-place, converting, assembly, and robotics, the network infrastructure must be capable of managing time-synchronization services and delivering data between devices in a timely manner. It's a tall order, but a free guidebook may help.
Rockwell Automation, Milwaukee, announces a 75-page addition to the Converged Plantwide Ethernet Design and Implementation Guide to help machine builders and manufacturers deploy integrated motion using EtherNet/IP networking technology. The new chapter — developed in collaboration with Cisco Systems — provides detailed design guidance, recommendations, and best practices to help control system engineers tightly synchronize motion applications within the plantwide architecture.
Traditionally, manufacturers have used a dedicated motion network, a strategy that requires specialized hardware and often results in a more isolated design in which information is inaccessible. EtherNet/IP is designed to connect from the device level to the end-user's IT infrastructure and across applications, including discrete, process, safety, motion, and drive control. By moving from dedicated networks to a single, integrated architecture for the plantwide network, users can reduce engineering time and total cost of ownership.
According to the new guide, by harnessing the IEEE-1588 Precision Time Protocol, the EtherNet/IP network delivers the deterministic control required for closed-loop position, speed, and torque regulation within a drive. Other industrial protocols use a time-slotted approach in which each device on the wire is given a specific time band for communications, requiring the end user to reschedule the entire network whenever a device is added or removed from the system. With EtherNet/IP, end-device clocks are tightly synchronized and information in the message is time-stamped with an accuracy of 100 nsec — so across any given control system, hundreds of axes can be coordinated for synchronized motion control.
To download a free copy of the guide, visit literature.rockwellautomation.com/idc/groups/literature/documents/td/enet-td001_-en-p.pdf.
Building Your Perfect Geared Motor Solution with Parvalux Modular Range
March 25, 2024
The Parvalux Modular Range enables you to quickly build your own geared motor solution using our online configurator. Choose between brushed or brushless motors, a range of ratios...
March 13, 2024
March 13, 2024
March 13, 2024
