Fluctuating scan rates no problem for chip imager
July 8, 2004
Nonstandard video input and an ability to handle varying scan rates were key in the development of an imaging system for focused ion and electron-beam machines.
Imaging on a DualBeam system sends video data from an electron detector to a Coreco frame grabber in a PC for display and output.
Images taken from a CLM-3D 300-mm DualBeam system are typical of high-resolution structural crosssection studies facilitated by the Coreco frame grabbers.
Called the DualBeam line, the semiconductor metrology machines let researchers and engineers poke around submicron structures. The machines use a scanning charge-particle beam to generate secondary electrons, which the system discerns via a special secondary electron detector. The detector output gets converted to a raw video signal, meaning it contains no synchronization signals. "The synchronization signals have to be generated by the beam control system, so that it acts like a camera in this application," explains Steve Rosenberg, director of engineering at the Beam Control Group of FEI Co., the Hillsboro, Oreg., maker of DualBeam machines.
The machine's image acquisition must also reliably handle scan (pixel) rates which fluctuate from slow (100m sec) to fast (100 nsec) within each application. This happens because the secondary detector is quite sensitive and thus generates a lot of noise.
A Viper-Quad four-channel frame grabber from Coreco Imaging does the necessary processing. It passes images to a PC, where they are controlled, processed, analyzed and output in hardcopy format.
One input of the frame grabber is dedicated to acquiring images from a CCD composite video source. The other three inputs acquire images from a slow-scan video source using an external vertical/horizontal sync and pixel clock or a fast scan video source using an external vertical/horizontal sync. As only one VS/HS input is provided for the latter three, they are, by definition, synchronized.
To help increase image fidelity, Coreco developed a hardware-based noise reduction algorithm that processes images in real time. This pixel averaging function "has definitely been one of the most helpful features in ensuring image quality and reliability," says Rosenberg.
The FEI Defect Analyzer Series systems (bottom) combine SEM imaging, focused ion-beam milling, and beamchemistry technology to help manage processes crossing the 90-nm design node. The machines characterize buried defects, important because more than 80% of today's defects occur below the chip surface. The ability to locate and visualize such defects and determine their root cause goes beyond what is possible with optically based tools and conventional defect review SEMs. Next-generation Tecnai Series machines (top) embed all microscope and detector systems including STEM, cameras, EDX and EELS detectors into one system. The high performance instruments resolve down to 1 °.
MAKE CONTACT:
Coreco Imaging,
(514) 333-1301,
www.imaging.com
FEI Co.,
(503) 726-7509,
www.feicompany.com
