Fittings For Fluid Conveying
New Seal-Lok Lite tube-fitting system offers a reliable, compact fitting solution for applications requiring high flow and low-to-medium system pressures.
April 13, 2006
The system is comparable to traditional Seal-Lok (SAE J1453) products, and also adapts to a line of light-duty, flexible, corrugated stainless-steel tube traditionally used in the gas-appliance industry. The compact design features shorter threads on the ORFS end, while fittings with SAE-ORB studs feature a light-duty port stud with shorter thread length. Fittings are also available with light-duty male NPT threads. Seal-Lok Lite assembles with existing Parflange tooling and equipment.
Parker Hannifin Tube Fittings Div., 3885 Gateway Blvd., Columbus, OH 43228, (614) 324-8227, parker.com
