FDA-COMPLIANT NYLON
It's internally lubricated via a permanently suspended oil that continuously lubes the surface. Internal lubrication doesn't leach out after machining or in use. Compared to other cast nylons, the material reportedly has an improved coefficient of friction, resists wear better at temperatures to 200°F, and machines easier. Nylatron comes in a wide range of rod, sheet, and tube sizes.
Quadrant Engineering Plastic Products,
Box 14235, 2120 Fairmont Ave., Reading PA 19612,
(800) 366-0310,
www.quadrantepp.com
