Fastners and Adhesives: Liquid-Adhesive Dispensing Guns
Two high-speed, rapid-cycling, electric liquid-adhesive dispensing guns are said to boost efficiency and productivity while delivering consistent, high-quality bonding
Feb. 17, 2009
Two high-speed, rapid-cycling, electric liquid-adhesive dispensing guns are said to boost efficiency and productivity while delivering consistent, high-quality bonding.
The LA 825 RC guns, with elongated reduced-cavity nozzles, are for small adhesive quantities, intermittent application, and high-line speeds found in folding-carton production. The LA 825 guns are suitable for the paper and paperboard-converting industries. Both applicators maintain consistent bead length regardless of line speed.
The applicators feature a 250-Hz continuous cycle rate, sharp adhesive cutoff, clean operation, and improved stroke adjustment.
Nordson Corp.
11475 Lakefield Dr.
Duluth, GA 30097
(800) 683-2314
nordson.com
