Expanded Wear Ring And Bearing Product Line
Nov. 3, 2005
A new 48-page catalog profiles wear rings and bearings for hydraulic cylinders.
Products include tight-tolerance WPT and WRT Series ( radial tolerances of 0.000/0.002 in. for sizes to 6-in. OD and 0.000/0.003 in. for sizes 6 to 12-in. OD), as well as commercial WN Series (radial tolerance 0.000/0.005 in.) for light, medium, and heavy-duty hydraulic cylinders. PTFE products include PDT and PDW profiles for light-duty hydraulic and pneumatic cylinders available in bulk strip, cut-to-length strip, or machined rings.
The catalog contains detailed information on wear-ring performance, design, and selection criteria. A Q&A Engineering section details selection of wear-ring width; provides tips on installation and various end cuts. Tight-tolerance wear rings of WearGard have good dimensional stability, high compressive strength and internal lubrication. Also offered are commercial tolerance wear rings of MolyGard and of PTFE that is 40% bronze filled, and 23% carbon/2% graphite filled.
Parker Hannifin, Seal Group, Engineered Polymer Systems Div., 2200 South, Salt Lake City, UT 84119, (801) 972-3000, www.parker.com
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
