Backpressure as well as high-relief applications are possible without a quick exhaust valve and additional plumbing. A solid-state sensor monitors pressure at the work port, then the regulator adjusts pressure by filling or exhausting air from the system. It can regulate pressure, vacuum, or be used as a programmable pressure-relief valve.
Proportion-Air Inc.,
Box 218, McCordsville, IN 46055,
(317) 335-2602,
proportionair.com
