The ED02 pressure regulator is a compact device measuring 76 X 60 X 30 mm. It has a directly-controlled 2/2-way proportional valve that allows an air flow of 3.5 Scfm (100 1/min).
Four ED02 series pressure regulators can be linked to each other without a base plate. Voltage supply, analog set point, and actual value are electrically connected via a central M12 plug. It is available with the IP65 (NEMA 4) protection, comes with a microprocessor that controls exact regulation, and provides repetitive precision of 0.44 psi (30 mbar) and values with a hysteresis of 0.73 psi (50 mbar).
Bosch Rexroth, 5150 Prairie Stone Parkway, Hoffman Estates, IL 60192, www.boschrexroth-us.com
